1969 Road Runner proper real window seal
Rhill5371
Hello. I am currently prepping the rear window flange to install a new glass. I have been curious to the correct seal for this. The original seal used a polyethylene material. I see only butylene rope available which would be fine but I am seeing 2 sizes. 5/16 inch and 3/8 inch. One supplier says that the 3/8 may keep the glass too high for the trim to fit. I this true or can I press the seal in firmly to avoid this?
Rapid Transit
Just A Traveler In Time
Amazon says people are buying this with it?????
Amazon product ASIN B000PEZAU6
  • URETHANE ADHESION: Specifically promotes urethane adhesion in automotive glass applications
  • PINCHWELD TOUCH UP: Can be used to inhibit corrosion on pinchwelds
  • EASY TO USE: Fast-drying and requires no activator
  • UV RESISTANT: Helps preserve urethanes for long-lasting windshield installations
