mike69rr
This is my first post, so go easy on the new guy. When I attempt to start my roadrunner, I must manually hold the key in the start position but it disengages the starter to keep the engine running. I thought it was the ignition cylinder so I replaced it and inserted my old key lock set and the problem still persists. Could the key cylinder effect this issue? Thanks.
