Oil Pan
abodybill
Senior Citizen Member
MI. Farm
I finaly got to take the oil pan off the engine that dropped alittle earlyier in the year from the cherry picker.
Anyway I really lucked out as all the damage was just to the pan crunched where the drain plug is and didn't even touch the pickup or windage tray. :banana: :thumbsup: :D
I have new windage tray and and gaskets what I want to know is do you use any RTV on the gaskets?
Looks like I did 9 year ago just want to know if use it or something else?
Maybe nothing?
I use a little high tack on one side just so the gasket doesn't move around with a little RTV in the corners. But that just me
same here.....its just the gasket or in place of it ....rtv
when I worked at the IH dealer, one of the mechs that rebuilt engines used weatherstrip glue. He said it's a bitch to get off, but it never leaks.
abodybill
MI. Farm
Dave,
Which one?
the green or black?
abodybill said:
Dave,
Which one?
the green or black?
Probably the 3m yellow "gorilla snot". I've used that in cars that I never expect to take apart again.
If you use weather strip adhesive on both sides chances are you will bend the pan if you ever need to take it off
abodybill
MI. Farm
I asked because I thought it was the stuff Big John had used and I know how that stuff works :lol:
I plan on using the spray high tack I got in the shop on only one side of each gasket and alittle RTV as told. :thumbsup:
