¿ could this be YOUR motor ?
vso737
California
ENGINE ID# 17782 A
with casting # 3614230-4
Can anyone ID these numbers for me. Let me know if it is in fact a 383CI and what it came off of.
Pictures attached.............
Thank you in advance.............
LG,
Mike
:yesnod:engine number- lower left bottom- 808.jpg
vso737
California
Well,
Further investigation........if I'm correct, the ENGINE # listed above is NOT the VIN# but the DATE code number. This number is taken off of the lower LH of the motor under the starter opening.
I will be looking for the VIN# stamping tomorrow. If I'm correct, it should be on the lower rail on the right side of the engine.
My research reveals this is a 1971-72 400CI motor.................
Any info greatly appreciated.
LG,
Mike
vso737
California
Well,
If I'm correct, the number 17782 A, taken from the block near the starter, is a DATE code. My research indicates it is APRIL 4, 2010...............
I'll be looking for the VIN# tomorrow..........
Any info greatly appreciated..............
LG,
Mike
vso737
California
Well,
I checked by pad on the RH by the distributor for some numbers with NO LUCK.
Any suggestions where I may find the VIN# stamped on the motor??
Thank you in advance,
LG,
Mike
On a B block it might be found next to the oil pan near the passenger side motor mount
vso737
California
Thanks, I will try and see what I can find. Will be under it again today. Spent half a day trying to install the STARTER and still not bolted on yet. The Hooker long headers make it quite a task...............Should be able to mate the tranny to the motor this morning. I'm NOT looking forward to installing the top two bell-housing bolts either................LOL
Hope I can come up with a number................
vso737
California
OK
I found the engine ID#. It is taken from the RH of the motor just above the oil pan.
The number is " 2C208217 "................
Can anyone tell me what this came of of.
Thanks,
Mike
