Well go to harbor freight and get the polishing compound they have buffing wheel's to fit drill's but I like the right angle air mini grinder. It has a chuck you can fit a lot of thing's into. Some one says they are aluminum but thought they where stainless steel. Either way you can do as good a job as a shop on the week end. Their was just some one on here with the one he did. A body shop is going to charge like crazy to do it. Just my thought's I like to do thing's my self. If I can. Good luck and sure someone else will give you some good advice also.
MCB Restoration in Capac, MI did my '69 grill. Stripped it and redid the Brite Dip. Turned out great. I'm sure that they could handle a '68 equally well. Contact info:
