WANTED 1968 plymouth roadrunner
Blown R/T
Coon Valley Wi.
I have deck lids. Décor or no? But I am in Wisconsin?? can get you pics if you want? need your email to send them to you.
Kevin
dmartin
Welcome from the peach state with the wave crazy Larry
crazylarry74
crazylarry74
hudson ma 01749
mine has trim on back makes no difference would be great if you had one in the same color of door in pic paint code uu1
Blown R/T
Coon Valley Wi.
I need your email to send you pics. I have a primer, and a oe paint lid . 1 fender. grills, and many décor panels.
Larry I bought my door's from AMD. Have put them on through out the build process and every thing looks good so far. Trunk lid's are hard to find. My lid came with the car and it had trim on it so got to fill the holes where trim fixed to it. Have a little issue with the corner hitting near the filler panel but will grind it down and weld it to fix the problem. Good luck on the search.
Had not heard that one. I am bed lining the inside of mine to help with sound travel and help with the heat factor. Once I put the bed liner on my roof and in the quarter panels they sound total different when taping on them. It dose help out the tin sound you get from the metal to more of a thud sound. :beep:
