FOR SALE 1969 Plymouth Road Runner HEMI
Not a bad looking HEMI car. Does need some thing's but overall look's good for original. For 50 year old car look's pretty new. :beep:
Petroleum1
AZ
The disconnected automatic selector still on the column is not a good look.
I like the clear plug wires and the heat tube to the choke is routed funny. Solid looking car though.
Petroleum1
AZ
Looking at the stick shift photos i see they did not add the hump for the shifter. It looks a little funky the way it’s mounted.
Yep no hump thus the super boot. Be easy to convert back if the buyer wanted an auto.
Guess I did not look too close at the column. Saw the floor shifter. Yes, no hump. But all in all the car dose look pretty good.
Under both window bottom trims look a little shaky, left rear quarter over wheel is rust. Inside of both rear quarters is rust, what is up with the junction of passenger rear fender and roof under top, blue seat belts??, pedal heights off, wrong pedal cover,
That I noticed for sure blue seat belts. What is up with that. You got a good eye quikbird. I am not intrested in buying it so just gave it a quick look. My BAD.
chryslerfan
Southwest FL
For a care with so many things that are not right, how is it called unrestored? Those blue seat belts are awful with that exterior and interior.
Petroleum1
AZ
They look blue to me. Maybe the original ones were removed at some point and lost. Then they needed some type of belting for registration inspection or whatever. The blue ones all they could come up with.
Russ Hood
TN
I'm thinking about putting a Hemi in my car. I know where one is at at about two miles from me. Man is older. What is an original one worth that needs a rebuild?
Plybeep68
Acceleratii Incredibus
Did the automatic birds come with color matching carpet? Both mine are 4 speeds and they came with black carpet, the 68 has a blue interior and the 69 had a green interior
Yes the Auto cars could get color carpet.
