1971 road runner Antenna Hole Missing?
road robert
Holden, MA
I have an antenna mounted on the RF fender but the coax wire is coiled up inside the fender and I checked with a mirror but do not see any hole to bring it inside the car through the kick panel. Can anyone please send a pic with the passenger door open showing where the antenna cable enters? Thanks!
On a 69 you have to pull the inner fender splash shield to see and put the antenna wire through the kick panel area. Don't know if they did the same with your car. But they did not change a lot for routing that antenna wire.
robertop
On my 69 I was able to stick my hand inside the fender with the passenger door open about half way, but my hands are pretty small and it was not easy anyway.
Got my arm up in the car in the back quarter to check something out. Thought I would never get it back out. Left some meat behind. OUCH!!!! Did you find the hole for the antenna wire?
