jays69bird
Okay guys,my 4 speed is not the original known that since I bought the car but the motor matches.I was taking the z bar out to rebuild it so I decieded to scrawl down the vin of the tranny to see what it was,the vin on the tranny was S23L9A146518,broke it down to a 69 either GTX or R/T with the first # missing I can't tell rest is 2dr 440 375 hp 1969built at Lynch rd.Now did the 440 come with the 18 spline like the Hemi or is it a 23 spline which is correct for a 69 383? there are other numbers that i can't decode,I have a hopping out of second problem and I want to rebuild so I want to order the right stuff when the time comes.Seems like if it was the heavier tranny you'd have to swap pressure plate flywheel etc.
