69 RR - no voltage reading at the alternator
Skingjack
YEG
As the title indicates, the alternator ( both new and old) does not charge the battery. A quick multimeter test of the battery indicates 12.6 volts. However, starting the vehicle and rechecking the battery shows only 12.2v. Of particular interest, checking alternator yields a reading of 0v.
Any thoughts on where to start with further testing? Do note that I’m a newbie when it comes to electrical issues/ multimeter usage.
Background info on parts replaced to date:
New dual field alternator ( previous was single but exhibited same problem - 0v reading)
New msd ballast resistor
New Napa voltage regulator
New world performance ( msd clone) RTR distributor
New msd coil
New msd wires
Muchly appreciated for any pointers provided.
Ian
Did you ground the second field to the case? Oh I can't remember everyones cars this is pre 70 ?
Skingjack
YEG
Forgive my ignorance Russ but what do you mean by “polarize the regulator”?. I’m not familiar with this term/ procedure.
Ian
With Alternator you may not have to do this but did it with my tractor instructions came with the regulator. Running an alt. on the tractor. You should find this on the web. Have to polarize the Reg. on a Harley with generator. It say any time you change the Alt. Or generator must do it again. This tells the regulator where the source is coming from and where to send it.
Danomt
Glasgow, Montana
"polarize the regulator" was a procedure on a Old generator system. Does not apply to alternators. Dual field alternators used a different style of regulators. Without knowing your system it will be hard to trouble shoot your problem The big wire at the alternator is really just connected to the positive battery post, so it should read battery voltage. never zero.... Need more info...
Skingjack
YEG
Russ,
Not functional as of yet- comedy of errors. To make a long story short, it's installed but not working. I need to re-install a brush into the second field then ground that field with a wire to an altenator bolt. A task for later today.
Ian aka Skingjack
Skingjack
YEG
2nd field on the alternator was grounded as it should been initially; unfortunately this yields no success with battery charging. This is getting frustrating but it will get figured out eventually.
Skingjack
YEG
Problem resolved with the 3rd voltage regulator we tried- a solid state version was the ticket.
Next up a/c plus heater core repairs could have used the a/c today... shouldn’t complain though ... nothing like Florida or Az weather in the summer. Thanks all for the suggestions.
Ian
Their you go one down. Glad you found the problem. Yep it is almost a given to have ac in Fla. Us old guy's need ac two window's down at 60 MPH dose not work well any more. :lol:
