70 roadrunner post weatherstrip vertical channel
Fernando
Does anyone knows where to get one of those ( passenger side)
69bfan
GA
I am not exactly sure which seal that you are looking for. Can you post a picture of the area in which your looking? If your looking for the mylar seal for the vent window division bar channel, they are almost impossible to find. If this is a convertible, the A-Pillar seal is available from either Soff Seal or Steel Rubber. The quarter window vertical seals are available from a variety of vendors. We have all of the pieces, but not really sure of what your needing.
69bfan
GA
To my knowledge, those pieces are not reproduced. So you will have to seek out a good used set. Probably want to start a "Want to Buy" thread.
I'm not sure what you are refering to either. Do you have a picture of what it is or where it goes?
Looking for the post metal channel
Got a lot of part's from Stephens mopar parts. In Alabama. Like the upper front roof trim. My car did not have it. Also other part's that was stripped from the car lid some trim piece's. They are not cheap but had what I needed. If you get a set put them in a plastic bag with WD 40 sprayed on them and in the bag. Let set in the sun and they will become more supple. Mine looked like new after being in the sun for a while on the back of my tail gate of the truck.
