Adding Spacer to clutch fan
Other Tech Stuff
  1. TOMRR
    TOMRR Well-Known Member
    432
    Dec 29, 2013
    Mass
    I need to at a small spacer to move my fan into the shroud . The current bolts are to short and it does not look like you could get longer ones in the space the is provided between the pulley and the clutch fan. I can seem to get photo bucket to work or I would post a pic.
    Any suggestion ?? I have a thin spacer that will be perfect
    Thanks Tom C.
  2. 69hemibeep
    20,048
    How far into the shroud is the fan? Ideally you only want the first 1/3 of the fan in there
  3. TOMRR
    432
    Dec 29, 2013
    Mass
    It rides just at the outer edge and I have never had a over heat problem . I have a hp440 with a 26 inch Radiator. May be not necessary ???
  4. 69hemibeep
    20,048
    That is better than too deep, I'd leave it alone
    TOMRR likes this.
  5. TOMRR
    432
    Dec 29, 2013
    Mass
    Thanks That's the Plan,
Share This Page
