clunking noise when turning right
the title says it all guys. the car is still at the dealer in florida. they sent me a video of the car and i heard the clunking when they make a right turn only. they have sent the car to a local mechanic they use to see what the issue is. tall the bushings, linkages, suspension under the car is new and tight. someone told me rear diff.....
wheel bearing, ball joint. my first two guesses without more info
well they told me it doesn't make the noise when theres only 1 person in the car but it does make the noise when theres a passenger. makes no sense to me. Only on right turns. I'm thinking the spider gear in the diff ?
Bet it's a loose wheel bearing.
or a loose wheel...better check your nuts........
Ranger
Woodstock ll
You don't mention what car or year you are talking about. If it is a modern FWD, then I'd say that sounds like a bad CV joint. If an older RWD, then I'd agree with wheel bearing.
