Clutch Safety Switch for 69 RR 4 speed
Fred69Runner
Not sure if this is the correct forum, but need to know if there is a way to prevent the starter from engaging if the clutch pedal is not engaged? Wanting to add this as a safety . Any help or suggestions would be appreciated.
Fred69Runner
Hi Russ, I saw where there was a switch on the 70 RoadRunners, but didn’t know if anyone had tried to adapt it to work on a 69 or how much wiring is involved. Thanks for the reply..
Don't turn the key :)
V.R.D
florida
you could maybe use an old ford brake switch as it goes over the bolt for the pedal and use it as a brake in the ground for the starter solenoid
