When I came home from taking the RR on another ride I seen brake fluid running down the inside of the tire to the ground and it seems like the whole drum had brake fluid on it. Probably something simple like a wheel cylinder. But if I'm converting the front brakes to disc, does it make sense to change the back to disc also. This is a non power brake car.
Getting some dieseling during shutdown of the car. Car ran fine on the highway, cooling down some, but the car diesels when I turn off the ignition then is a little difficult to restart. I have a Holley 770 Street Avenger.
Third minor problem, it sounds like the exhaust is hitting the starter, K frame or something. Its especially knocking after the car is warmed up and I depress the clutch.
Slowly getting it back together hopefully to get it into paint somewhere in the next month.
Thanks for the help,
Barry
Barry
