1. Terry Hauck
    Terry Hauck Choadicus
    82
    Sep 6, 2017
    Mojave Desert
    Want to change over to disc but the kits I have found for 11 inch drums need spindle replacements. That involves a lot more skill than what I want to attempt and paying someone is expensive. Any suggestions?
  2. Coyote
    Coyote Well-Known Member
    542
    Mar 6, 2016
    Columbus, OH
    :steering:I used the changeover from Right Stuff. The spindles were included. Been on for years. They may have a kit now that fits drum spindles. The changeover was NOT that difficult.
    Torsion bars are a ton easier (and safer) than fighting springs.
    I believe Wilwood has a kit that fits drum spindles. Definitely not cheap, used their Tri5 fronts on my ‘55. Value received.:beep:
  3. quikbird
    quikbird Well-Known Member
    2,158
    columbus, ohio
    Stainless steel brakes has a set that fit drum brake spindles
  4. Terry Hauck
    82
    Sep 6, 2017
    Mojave Desert
    Thanks guys
  5. Big John
    Big John Sit back, relax Don't bitch about the cigar smoke
    5,010
    Simple... Don't change them.
    The drum brakes on these cars are huge. 11"x 3".
    What I'm saying is to not buy into the hype of people trying to sell you disc brake kits. It's not as much of an upgrade as they have you think.
  6. Terry Hauck
    82
    Sep 6, 2017
    Mojave Desert
    I can't get the drum brakes right. I've changed everything and they still pull to the right. Put left on right everything.
  7. Big John
    5,010
    You just need to figure out what's wrong.
    First... Are the shoes on right? Short shoe forward? I've seen guys put the long shoes on one side and the short shoes on the other.
    Hoses good? Cylinders? Wheel alignment good?
  8. 69hemibeep
    19,844
    Internal breakdown of a hose will drive you nuts
    Big John likes this.
  9. Big John
    5,010
    It's a very short drive for some of us.....
    Coyote and Blacktop Voodoo like this.
  10. 69hemibeep
    19,844
    Yep
  11. Terry Hauck
    82
    Sep 6, 2017
    Mojave Desert
    Short shoe up front. New hoses cylinders springs everything new. Maybe it's in the lines from the master cylinder. The car is almost 50. They stop great when they are even. I will keep at it.
  12. 69hemibeep
    19,844
    If you ever trailer it look for a mashed steel line on the diff. Don't ask me how I know.
    Fatty likes this.
Share This Page
