Excessive Cylinder Skirt wear hp440
Engine & Related
  1. TOMRR
    TOMRR Well-Known Member
    362
    Dec 29, 2013
    Mass
    What would cause excessive cylinder skirt wear on only two Cylinders in a rebuilt 440 with two summers of driving and about 3500 miles
    Thanks Tom C.
  2. quikbird
    quikbird Well-Known Member
    2,007
    columbus, ohio
    Check bore diameter. Excessive wear is usually due to too much wobble on the piston. Piston could be too small or those cylinders a little bigger.
    TOMRR likes this.
  3. IQ52
    IQ52 Member
    22
    Apr 10, 2016
    Challis,ID
    Somebody put an engine together dirty? What does this "excessive cylinder skirt wear" look like? Pictures?
  4. quikbird
    2,007
    columbus, ohio
    Excessive scuffing on the skirts. Usually caused by too much piston slap
  5. RKNRLR
    RKNRLR Well-Known Member
    118
    Mar 27, 2017
    Sydney, Australia
    ill go with too much piston knocking too. had the same issue with my 440 before i pulled it down. had it bored .040 over (was at a rough .030 already) just to clean it up. also had all the new rotating gear balanced. They took some material off of 2 piston skirts, but none of the others.
    runs like a new watch now.
    TOMRR likes this.
  6. TOMRR
    362
    Dec 29, 2013
    Mass
    My engine builder is saying excessive full dumping( Carb Issue) into cylinder and it wash down two of the cylinder skirts, He found a piece of metal in 750 Holley. Not a clue where it may of come from, There is a filter after the pump and the metal fuel line looks ok. He said it was to big to pass through the filter. I am having a hard time buying into that reason but then again I am not a motor guy.
  7. dmartin
    dmartin Well-Known Member
    434
    Aug 30, 2013
    Somebody accidentally left some foreign substance in the block sounds to me as far as the fuel dumping I don’t know that’s a new one on me man maybe he didn’t change out two sets of rings that’s the reason I like doing things myself if I don’t know something I get somebody who knows and let them look over my shoulder
    TOMRR likes this.
  8. popslavaz
    popslavaz Member
    22
    Jan 13, 2017
    Channahon,Illinois
    Could be a pin issue,not letting the piston center after direction change. POPS
  9. BOB KAMMER
    BOB KAMMER 1969 Road Runner
    9
    Apr 16, 2018
    45424
    I AM GOING WITH THE CARB FLOODING
    TOMRR likes this.
  10. Russ69Runner
    1,254
    Never heard of metal getting past the fuel filter into the Carb. Had to been in a line or some fitting when putting the Carb. on or replacing some part of the fuel line to it. It is possible to wash a motor down by over fueling. No oil hence excessive wear on cylinder wall and the piston as well as ring's. If you pull the dip stick shortly after doing an oil change and smell's like gas think you have a problem. This is usually to much carb for the motor. Hope you get it worked out. Russ.
  11. 69hemibeep
    19,564
    Yep, if your oil gets dirty quick its fuel
  12. perfetech
    perfetech Member
    6
    May 6, 2018
    You never mentioned the cylinders numbers of the two bores.
  13. TOMRR
    362
    Dec 29, 2013
    Mass
    It did not get past the filter.
  14. Russ69Runner
    1,254
    Boy that is a good thing. Witch cylinder's had the piston skirt wear. Led and lag some time have these problems. Led being number one and number eight being the lag. So that being said let us know which one it was weather number 4 or what ever. This would be interesting to know. Thanks Russ.
    TOMRR likes this.
  15. halftrackman1
    halftrackman1 Active Member
    36
    Jan 20, 2018
    tn.
    did you have a windage tray in the engine. I don,t not use wind trays, I think they cause piston wear, I like all the oil to fly around in the engine, Also number 1 piston and cylinder will have more wear, the torq start at number 1. I may be wrong too. just my thinking, no I not drinking
  16. TOMRR
    362
    Dec 29, 2013
    Mass
    Yes I am using a windage try, Some how a sliver of metal got into the 750 holley and it stared flood the engine with to much fuel This all happen on the second summer of driving and about 2500 miles. plus there may have been and issue with one two pistons not sure witch ones the engine is back at the builders and replacing piston for free, no damage to cyl. walls plus a cut rate for the Labor.
Share This Page
