front door inner panel and backseat arm rest.
So is the front inner door armrest bases 13 inch. and takes a 9 inch arm rest pad. now was their a rear arm rest for the back seat. I see in classic a 9.5" base so dose it get the same arm rest pad as the front. I looked into Manuals but could not find what I wanted to know any help would be grate. Russ.
Rear was an option with ash trays also. And uses the same pad as the front.
IIRC the '68-'70 Chargers had a longer front arm rest and base than the other B Bodies
dmartin
I don’t know if mine is right or not but I have a 13” on the fronts and a 9.5” base I don’t care about the rear I don’t sit back there
There is a rear one and it is shorter. How much, can’t tell you till I get over to the shop and measure it.
