Fuel Line Crimp Clamp
MsBeep
Alberta, Canada
I would like to change the length of 5/16" rubber fuel hose that connects the metal fuel line from the gas tank to the fuel pump inlet on a 383 Engine.
It looks (and feels) like it's been on the car since '69. It still has the factory installed Oetiker, or crimped clamp attached there at the lower edge of the passenger side fender, in the engine compartment. It is hard to see and harder to get a tool on. Has anyone changed the hose with this style of clamp? Is trying to cut it off my only option?
earlyrides
SoCal
No need for any fancy tools.
I have done it with a pair of side cutters (dykes) several times.
If it does not cut right away a few twists back and forth should get it loose nough or even cause it to break and then it can be easily removed.
Die grinder and sparks not reccomended.
and do yourself a favor and put reglar hose clamps on. I've pulled hoses off by hand that have had the crimp clamps on them.
MsBeep
Alberta, Canada
Already purchased reg'lar hose clamps; made in USA:flag: and will be avoiding sparks, open flame, and filling the gas tank, until it's done! Thanks again.
