Fuel pump pushrod
Mike D
I have a 1969 440 fuel pump pushrod is really worn. Purchased the car last year I know Edelbrock RPM package was installed with hydraulic cam before I purchased The pushrod that came out I think it’s original do I need a hydraulic fuel pump pushrod?
Pretty sure all fuel pushrods were the same. All went to a mechanical fuel pump and I think all different cams had same eccentric to run pump
It only take a worn out rod to give you problem's. Cheap enough to replace with a new one. When having my motor rebuilt insisted on that being new put in also.
