I tried to install my locks Friday and discovered I could not get the clips to go back of the little tabs. So I checked the thickness of the door now that it is painted. I got my trusty little micrometer out and sure enough with the coats of primer/base coat and clearcoats, the door is thicker than OEM. I used my Dremel to remove a small amount off the cylinder tabs. Still will not fit. Anyone else ever have this problem? Not sure how to fix this. Any help here would really be appreciated, BIG MO.
