Lights dim when I step on the Gas pedal
dhansen_69RR
Mississippi
Hello all fellow RR friends! I just wanted to throw this out here to see if anyone else has seen this or if this is normal for these cars. I have noticed at night when I have my lights on when I accelerate I notice all the lights go dim until I let off the gas pedal. Even when I crank it in the garage I will step on the pedal to rev it and the lights go dim. Has anyone else had this issue? Thanks!!!
mr4speed
leesburg florida
I believe the problem is when the lights go dim at idle either the batt is not fully charged or the alt or ground is at fault had the same problem.:BangHead:
