Jack R
Sure enough shaft won’t fit into the bushing. How can this be sized....in an assembled engine...well oil pan is off anyway. Any help is greatly appreciated.
Oil pump is attached to the outside of the engine. Just remove it and fix it or replace it.
You'll have to remove the oil pump so you can insert some type of dowel rod and drive the bushing outoil pump isn’t the problem. Bushing ID is undersize to the distributor/pump drive shaft. Won’t assemble
