Speaker / fader switch under the dash nee wiring info
bigmanjbmopar
Mine was cut loose and can't tell by the diagram how it connects, only one speaker output on the AM, was there two on the AM/FM? how does it wire up?
:missing:
Budnicks
Sonora Ca.
did you try over @ mymopar in there wire diagrams under tools, maybe the 1968 Belv. GTX Sat.& RR "Full" {pdf download} might help it has speaker wiring stuff on page 3 Instrument panel Accessary Wiring should be the same between 68-69 IIRC... I didn't see it under 69 for a full PDF download... I tried to load the link it doesn't work, sorry... That might be helpful, it has several speakers in the diagrams, left right & center, click on the photos there & it will enlarge them if needed... good luck
My FM only has one set of speaker wires and splits at the balance (fader) knob.
In the FSM, on pages 8-122 and 8-123 is the wiring diagram that you need.
The 69 FSM is always available in our reference section if you don't have one.
