6R9Runner
If the body and frame are solid, are subframe connectors required for hemi cars? Will a post car handle more torque than a hardtop?
Depends on how much power is being transferred to the ground - no matter what the engine is. If you have 1,000 HP and are running street radials it isn't going to hook up anyway so it really doesn't matter. If you have 400 HP & drag radials or slicks you might want to consider them.6R9Runner said:If the body and frame are solid, are subframe connectors required for hemi cars?
Yes. Any number of guys on here will describe for you how their quarter panels have cracked at the top of the door jamb on their hardtops from that area being inherently weaker due to the absence of the post.6R9Runner said:Will a post car handle more torque than a hardtop?
ACME A12 said:Depends on how much power is being transferred to the ground - no matter what the engine is. If you have 1,000 HP and are running street radials it isn't going to hook up anyway so it really doesn't matter. If you have 400 HP & drag radials or slicks you might want to consider them.6R9Runner said:If the body and frame are solid, are subframe connectors required for hemi cars?
Well? :toetap: :toetap:Hoosier Bird said:I've got one of those cars that was raced.......a lot.........and I can post of pic of what the quarter panel will do if you like...... :yesnod:
I agree if your cars not an OE RESTORATION , install them they are great .george68hemirr said:install them :acme:
pics ? do you even have to ask? :toetap:Hoosier Bird said:I've got one of those cars that was raced.......a lot.........and I can post of pic of what the quarter panel will do if you like...... :yesnod:
george68hemirr said:WITH THE SUB FRAME CONNECTORS MY QUARTERS RIPPLED AROUND THE WHEEL WELLS.....DUH....THE REAR.....TORQUE CITY
George when did you ever abuse anything other than the Joke section :jester:george68hemirr said:WITH THE SUB FRAME CONNECTORS MY QUARTERS RIPPLED AROUND THE WHEEL WELLS.....DUH....THE REAR.....TORQUE CITY
Awesome- another welding project! :banana:george68hemirr said:install them :acme:
Thanks- that should save some money, I'd like to see what you have in mind. :cheers:toms69rr said:Bought me some 11ga 2 x 3 tubing today, going to make me a set and install sometime this month
let you know how it goes
