Timing For 400
Rstockbridge
Does anyone know what the timing should be for a 400 with a 727 auto, headers aluminum intake and cam with the following specs:
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:2,000-5,800
Intake Duration at 050 inch Lift:227
Exhaust Duration at 050 inch Lift:241
Duration at 050 inch Lift:227 int./241 exh.
Advertised Intake Duration:279
Advertised Exhaust Duration:296
Advertised Duration:279 int./296 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.486 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.473 in.
Valve Lift with Factory Rocker Arm Ratio:0.486 int./0.473 exh.
Lobe Separation (degrees):107
Camshaft Gear Attachment:1-bolt
Computer-Controlled Compatible:No
Coyote
Columbus, OH
I’d go with about 30 degrees total (combination of initial, vacuum, centrifugal) to start with. Conservative, you’ll probably end up about 34-36 after tweaking for best performance. Good luck!:thumbsup::beep:
Coyote
Columbus, OH
Above was suggested for ignition timing. If you want cam timing, I’d go with straight up unless you are going to degree it in.
Most aftermarket cams are ground with some advance to start with.:beep:
dmartin
Are you from Ga
