Well done plug wires
Pete
Phoenix Arizona
Howdy. I have a 1974 with a 440. keep roasting plug wires. Some due to movement, but some due to heat from the headers. Have insulated boots, but can anyone recommend a good heat resistant plug wire?
Might need to get a plug wire heat shield to run them in. Or try to see if they have a fiber glass sock to go over them. Try summit racing or Jegs.
Pete
Phoenix Arizona
Thanks for the feedback, Ill check it out.
Pete
Phoenix Arizona
This is what I purchased. Worked well.
MOR-73800
Spark Plug Wires, Ultra 40, Spiral Core, 8.65mm, Blue, 90 Degree Boots, Universal V8, Set
(Mfr. #: 73800)
SUM-350160BLU
Wire Sleeving, Insulated, Slide-over, Silicone Rubber, Blue, 25 ft. Length, Fits 8.65mm Plug Wire Diameter
(Mfr. #: SUM-350160BLU)
Yes and they did not have this kind of stuff back in the day. Our 440 with headers was really bad about the back plug wire's being over heated. :thumbsup2:
