What Carb 73 RR w/ 440 for street
mopar1969
pa
I thinking about a new carb for the 73 RR 440. This if is for street fun, it has an improved cam. what are do you guys like?
3310 Holley with adjustable vacuum secondaries is what I would use. 750 CFM
Vacuum secondaries for the street.
Agreed. Double Pumper for manual trans car or manual valve body auto bracket/street car. For street use you will want the vacuum secondaries. Install a secondary spring quick change module if the carb doesn't come with one. 4 corner idle is nice too. Helped smooth mine out at idle.
