azmopardude
- Joined
- Aug 11, 2010
- Messages
- 11
- Reaction score
- 0
Would like some imput on what octane gas I should use and which lead additive is best? also we here in AZ have the MTB and alcohol added to the gas at different times of the year.
mcmopar said:That depends on how it runs. Will it run on regular or mid-grade ok? Back when I had my 1st runner it would run regular in the stock 10:1 compression engine. My present engine has 10.5:1 + compression and with some timing adjustments it runs regular unleaded just fine in everyday driving. If I wanted to romp on it I'd run premium, though. Now that my 383 has the iron 452 heads with hardened valve seats I can use unleaded gas with no issues but 906 heads will need some lead protection to keep the valves from receding into the heads. I used to run Max Lead 2000 to help increase the octane of pump premium but it isn't easy to come by anymore since the distributor went belly up. There is another lead additive called Lead Supreme you might want to check out.
http://www.wildbillscorvette.com/prod01a.htm
This stuff will protect your valves but if your state does roadside emissions tests you better check and see if it is legal there. This is the real tetraethyl lead that used to be added to gasoline back in the muscle car heydays.
Oh come on, us older guys grew up with that stuff and didn't suffer any brain,,,what was I talking about :basketcase:SomeCarGuy said:You don't want to breath in real lead anyway. That is some SERIOUSLY bad stuff.
I run 93 in my car, never tried anythign else. I figure it costs less than 100 a year extra to run the good stuff versus lesser grades.
Jim S. said:Well here is what I do. Maybe it is totally wrong but, that is just me. I am lucky, I have a Citgo station nearby that has 110 leaded race gas. I mix that 50/50 with 92 unleaded non-oxy. That brings me to 100 octane give or take. I have no idea if this engine has hardened valve seats or not. I still run points and a condenser because I like it that way. I do not have a fancy dial timing light or have ever installed timing tape on the damper. I just do it the old school way. Rev the engine and turn the distributor until it knocks. Then back it off. Take the car out under load and beat on it. If it still knocks, back the dist. off a little. Best guess with the timing light is that I am at 13 to 16 degrees advanced initial because it is off the scale. Car runs great with no hesitation and the smell of leaded race gas is great. At least that is what I was told before the brain cells fried.
