where to buy the front lower control arm bushing and rubber
Big Block
Jackson, MO
can anybody tell me where to buy the 2 metal bushings that go in the front lower control arm, and the rubber that goes in them. Or if it comes in a kit? I need the whole assembly. I've seen guys on U-tube that had the whole piece and put a pin in it and just press them in.
I like the rubber ones, they come as a unit. If you go polyurethane then leave the metal sleeve in the control arm and if needed use a propane torch to burn the rubber out. Not on the car of course
Classic has most of what you need for the K member. You may call Summit but I see they don't have a lot of Mopar stuff.
