Loosen the frame rail side lift up and it falls apart if the linkage is disconnected. No reason to remove the ball off of the bell housing unless its wore out
Watch out for the little nylon pieces around the ball inside the z-bar. You will need them to reinstall it. They fall off pretty quick when you slide it off .
I took an old accelerator spring, enlarged few coils to fit the slots in the plastic pieces, and cut off a single coil. I then put the two plastic halves around the ball and locked them in place with the cut coil. They cannot fall off now.
