Well here's a little T7...
Collin
DBC Deltron 2000 base with Deltron DCU 2042 clear
Trunk only so far
ImageUploadedByTapatalk1381712163.591995.jpgImageUploadedByTapatalk1381712172.874718.jpgImageUploadedByTapatalk1381712179.308304.jpgImageUploadedByTapatalk1381712185.358082.jpg
Collin
Can you tell that's a two piece replacement floor pan? Or that the lower wheel housings were destroyed?? Shhhhh
3BIRDS1X
Moderator
Mukwonago, Wi.
Not to be negative but are you sure that is enough coats? T7 should be on the dark end of the bronzes, might be good to compare it to an unpainted original part if you do have something, or it could be the camera lighting if so well never mind me. its just that the paints can be pretty transparent as I found out the hard way. regardless good job on the progress!
:drool::drool::drool: man - I wish I could paint mine that color....
Slow pitch...right down the middle...trying hard to lay off...so inviting...must not cave in to temptation... :basketcase:
Looks great, Collin! :cheers:
don't mind Johnny Mc Mopar...he just had a brain fart anf knows not what he says....
It could be that Johnny meant if he didn't already have the best color on his car, then T7 would be his next choice over any other color, I know it would be mine!!!!
Collin
The T7 matches exactly to the package tray original color and that on the window channel. The color changes tremendously in every light. It was totally different under fluorescent, no light and sunlight. And pictures never do color any justice! Ill post a difference of the 3 lights
Collin
ImageUploadedByTapatalk1382482005.158073.jpgImageUploadedByTapatalk1382482017.607452.jpgImageUploadedByTapatalk1382482024.958462.jpgImageUploadedByTapatalk1382482032.057589.jpg
Top two pics are under shop light
Dark pic is under overhead fluorescent
Last pic is sunlight
