Rear Package Shelf
I ordered a new set of carpets today. When I install them I want to repaint the rear package shelf while I have access. I could (and probably will) check the FSM I have stored in my computer on how to remove it, but thought I'd ask here first.
Remove the back seat and there are 2 bolt on clips that hold it in place. Or so I have been told as my back window has a zipper. :basketcase::basketcase::basketcase:
front of the back seat sits in two clips that you need to push back and up to clear, the back of the seat has a couple bolts at the bottom and then push it up to clear the two drop into brackets at the top. as previously mentioned that leaves two small clips to remove and out it slides.
just to give you an idea what is behind the seat
Cool, sounds easy enough to slip into the carpet replacement without wasting too much time.
for carpet just lift up the front of the rear seat and slide it under, for the shelf the whole seat must come out. the front bracket is right next to the drop light in my picture. one on each side
you don't know the pic whores on this site.......
so Bobby I guess that means you're one of my Bitches......
