WANTED 68 Roadrunner Parts
Jessejames
-Looking for some door panels in black. Looking for decent panels. Don't have to be perfect. Will dye them if I can find a good set. Just need the fronts.
-Under dash wiring harness
-hurst comp plus shifter
Any help would be greatly appreciated
Just want to recommend going with a new harness if available. 50 year old wiring the insulation is shot and the bulkhead connector is suspect. Legendary has new door cards also
Steve Roy
New Member
I have a good used set in black in my shop attic. I will pull them down Sunday am if you still need them. I can send pics then if you want. Steve
