key lock cylinders
Big Mo
Pa. USA
I tried to install my locks Friday and discovered I could not get the clips to go back of the little tabs. So I checked the thickness of the door now that it is painted. I got my trusty little micrometer out and sure enough with the coats of primer/base coat and clearcoats, the door is thicker than OEM. I used my Dremel to remove a small amount off the cylinder tabs. Still will not fit. Anyone else ever have this problem? Not sure how to fix this. Any help here would really be appreciated, BIG MO.
That is what happens with after market part's Big Mo. It is a pain in the A. I am just getting to that part on my car. Let us know what you find out buddy. Russ.
Big Mo
Pa. USA
thanks Russ but the thing is I am using the oem locks.
So the door is original also. Like I said now you have me wondering what or how mine may work Russ.
Big Mo
Pa. USA
the locks came off the doors. My painters used at least 3 coats of primer- sealer-base coat-and 4 coats clear. I think that buildup made it thicker than oem.
That could be true. Yes I have quite a few coat's of primer/base coat/ color blender with flake in it then three coats of clear. The thickness is only in mill's but that is a lot some time's. Hope you get it figured out. Oh plus I bed lined the in side of the door's. I may be in real trouble.
Big Mo
Pa. USA
Hi Russ. I went and talked to my friend that done the body work on my car. He does not restore cars he builds custom cars. He designs cars of all types so he makes parts and pieces all the time. He told me to grind the little ears off the lock except on top where the square chrome piece is. Put lock in door and put a small hose clamp on the inside replacing the clip. Works fine.
Thanks for the info Big Mo. A fix is a fix. Let me see what happens when getting to that point. Russ. :BangHead:
