Fire wall insulation Part two.
Ok found out where that pieces goes. It goes on the back of the heater box. So guess I will glue it to the fire wall. I have a Vintage air going in this car. So this dose make sense. :thumbsup2:
Big Mo
Pa. USA
Russ, I was going to tell you I did not need to remove the insulation on mine but after seeing your pic. mine is way different. I thought about air but did not put in. Spring and fall in Pa. sometimes calls for heat.
