Just to say the front sway bar had a bad grommet bracket. Must have hit something with it. Had to cut it and reform it to is original shape. Then weld it back to the mounting bracket. Got the new bushing's to go in them. The instruction's where to put the bracket on the sway bar then slide the grommet on. Then put the grommet into it's bracket. Said start the bottom in then work the sides and top in. Suggested soap- oil to lube it up then take a pair of plyer's to work it into the bracket. I must say it was a job. Was mad as hell messed up the paint job on the bracket's. It took two set's of channel lock plyer's and a lot of effort to work that darn thing in. Just about give up a couple of time's. I must say it is not an easy job for such a small part. But got both done. My choice of lube was KY jelly. Too much on the first one and had to clean it off put just a little on the edges where it met the bracket. My hand's are killing me now. So all that is left is to touch up the paint that was skinned off the bracket. Hope to get it installed tomorrow. Can say I have the original one's that came with the car.
