Adjusting door window's.
Have opened up the mounting hole on my vent widow frames. Adjusted the bottom pivot bolt. Window is too close to the gasket at the post. Door shut's tight. Is it my seals. Or just me. It is like the window is too big. When rolling up the window it wants to roll up in the gap of the seal. When up it presses tight on that area and dose not clear the outer fold. So what to do. The passenger side is better than the driver's side. Just don't figure. The door fit's well with the body. With window down it shut's fine. With window up it shut's hard. Any help or suggestion's are appreciated. Just about ready to roll it out for my first drive and want to get this cleared up. Russ.
