When I had my car in the shop I asked the guy to check the front end for any potential problems. He found a bad idler arm which I'm replacing today, and he said a lower ball joint is starting to show some play but is safe to drive for now. My question is what kind of job is it to replace the lower ball joint? Is this a screw-in type, or is it pressed in? If it's screwed in are there any special tools needed? I'm looking to save a little money here and maybe do it myself if I can. Thanks.
