Block Sanding
As you all know now that the metal is on!!! Here comes the block sanding and filling. It is a tough job but someone got to do it. Look for just a hood skin but only can find hole hood's if any one knows where to get the skin. Let me know. Still working on the sail panel area and around back window. Trying to get all that metal stacked on each other to level out. Skimming welded areas and doing clean up. Closing up holes where ever I find them. Sealing up every thing I can except the drain holes. Found some filled full of seam sealer on the upper cowl when I replaced it. Well will post some pic's when I get more along on it. :D
