Clutch Pedal
MikeMeep
Chino, Ca.
I was driving this weekend and thr clutch pedal will not pop back unless I pull it up. I can still depress enongh to engage clutch. Has this happened to any else? Does anyone know what to do to repair it?
Beekeeper
TN.
sounds like your bell crank/Z bar needs bushings time for a service on it. also check the clutch fork return spring
Sixtynine_Bird
France
About the clutch fork return spring, where should it be hang on to? The previous owner putted it on the tube of the exhaust manifold but I do think for sure that is not the right place... Am I wrong?
Sixtynine_Bird
France
is that the only return spring you have? I'm going to check back my pics when I disassembled the car but I do remember the one which goes in that bell housing hole and if I remember well there was another spring that goes from the fork to the headers with a sort of clamp to fix it. was a very strange linkage though... :huh:
Thanks for your reply Basketcase :)
just supposed to be the one spring. it can be a real pain the get stretched back and installed into the hole.
The over center spring on the pedal itself is used with standard Borg and Beck 3 finger presser plates. Diaphragm clutches and certain other manufacturers want that spring removed so the the pedal returns.
I never had any trouble getting it into the hole...........
Coyote
Columbus, OH
Good Grief, this crowd just spreads sweetness and light where ever it goes!
Actual answer: Adjustment (first try/probably it hopefully ), Z bar bushings, over travel spring. One of those for sure ought to get it unless clutch itself is on the way south.
mine did that when I first got it, after I replaced the home made adjustment rod, and properly adjusted, clutch works fine.
MikeMeep
Chino, Ca.
Ok, I got all the parts. What type of grease should I use with the nynlon bearings when they go into the torque shaft? Keep it clean...
