Clutch
TOMRR
Mass
I have the motor out of my 69RR and at this time would like to replace clutch, pressure plate and throw out bearing. I currently using a 12 inch McLeod set up and seem to be working well. I have a few miles on this clutch and seems to be fine , But feel that seeing that motor is out might as well put in new !! Any outer Clutch Brands Recommendations would be helpful.
Thanks Tom C.
What does the disk and the plate look like? Any discoloration on pressure plate?, how much wear on disc?
A new throw out bearing is highly suggested. Any time we pull one always replace it. What's up with the motor being out. Russ. :D
TOMRR
Mass
Not sure started to knock, On it's way back to the engine builder,
TOMRR
Mass
The pressure Plate is a 3 finger McLeod and does have some discoloration , the clutch disk and plate have about 3000 miles and disk looks ok to me.
sounds like if have plenty of thickness on disk, can re-use those parts. good luck on figuring out the knock
TOMRR
Mass
STREET PRO
Part Number: 75109
Street Pro Clutch Kit Chrysler,Dodge,Plymouth 10.50 x 1 x 23 Spline 10.50" Diaphragm Organic/Organic Disc Learn More
Regular Price: $228.58
This is what I am thinging
TOMRR
Mass
Sorry TOMRR hope it is a simple fix. Russ. :D
Yea Me Too , motor is out and the 20th of Oct. will be going back to engine builder I spent big $$$ on this motor and put 3000 easy !!! Miles on it for two summers !!!
I run a twin disc mccleod clutch and have had good luck with it. I tried single disc clutches and they just couldn't hold it and burned up way too fast.
What size motor are you running. I got a 383. Now you guy's have me thinking about what I have for the clutch. But not going to make a race car out of it. Want a driver but can show the mussel if need to. LOL. Russ.
It is all a function of power level and purpose. If running fairly stock horsepower level and driving, regular clutch should do you fairly well. As horsepower goes up you need more grab in the clutch. The problem is in order to get enough grip on the clutch the strength of the pressure plate goes up. This means it takes more work on your leg to work it. If you are 600 hp and a 3500 lb car a single disc clutch needs a lot of leg to work. Not comfortable as a regular driver. A twin disc clutch makes it much easier to use.
RKNRLR
Sydney, Australia
Got the jelly legs the first few times I took my bird out on the street!
