Engine Mount Hardware
Collin
Looking to finally drop the motor into the car. I have the old bolts and brackets for the engine mounts but not the washers. I noticed on a few websites they mentioned Chrysler used thin washers for the application. Can anyone tell me the specs for the washers so I can run out and get a few?
I also noticed that the trans mounts now are $30-50 in price. I went to autozone and bought a mount for $6. Going to take the old and compare to the new tomorrow... Hopefully it will work we will see
not sure on the washers, not a numbers /show car guy myself, I'd just grab what would fit the bolts. And that $6 mount no doubt came from China.
Collin
YA already don't like the Korean autozone mounts... Sprung $100 for the mitymounts heavy duty
Matrix2
Palm Springs, CA
I would suggest looking at a high quality left engine mount, like Schumacher as it gets a lot of stress. Stock is fine for the right.
mahoney0_00_3
whitehouse sta new jersey
16964_103884009636159_3729697_n.jpgbuy a engine mount strap a steel cable with 2 eyelets one side go"s thru K frame bolt -other go's thru the bolt on the ear of the engine block works great and cheap--and you don't see it
