Firewall
Ron
I need a section of firewall on the passenger side of my 69 runner from inner fender wall to the side pannel i dont want to replace the whole wall just repair some damage from an accident years ago thanks
How bad is the damage. You may be able to get a half section and cut what you need out of it. Some said that the fire wall replacement came in two section's. Check with AMD.
Ron
The damage is about 14 inches wide AMD sells the side panel the damage is above the floor seem up to the cowl i cut a section of a charger that a freind had but the metal wont take to welding it is to thin from years of exposure
I can confirm welding to the old metal is a challenge for sure. Had to turn my welder down and tack weld it instead of a steady burn.
