Fuel line routing
bill king
nc
I have a 69 roadrunner with the 383 engine Most of the fuel line was already off when I got the car. Can any one help with the routing of the fuel line from the rear chases to the fuel tank. I have only one fuel line. Pictures would be great Thanking you in advance Bill
Keep in mind this is a hemi car so there is a 1/4 return line you wont have
several companies also make a fuel line that is prebent. it comes back along the pinch weld seam next to the sill plate under the door and then cuts back under the frame rail, ( under as in the ground side, not between the body and frame) just near the front of the axle and then over to the tank
bill king
nc
Thanks, with good internet friends I might get this car together Bill
