Ground for wiper motor?
Trev3434
San Francisco Bay Area
Just curious, where is the ground for your wiper motor grounded to? Location? Pictures please, just trying to get mine back to factory location.
Thanks
69 Roadrunner
pretty sure there is a metal strap that comes from the motor that goes over one of the mounting stud.
Trev3434
Any pics? Not following ya... So ground wire from the metal stap that holds the heater hoses to the ground peg of wiper motor? Or ground wire from the ground peg on the wiper motor to a mounting stud where?
Two speed has strap running to the top r mounting stud. Since motor is mounted on rubber isolators a ground strap is needed .
Trev3434
Aw yeah I see! Thank you! One more question where is the ground wire grounded from on the windshield wiper fluid reservoir tank?
the washer jug ground should be attached to one of the screw holes, and gets grounded with the mounting screw.
