Master Cylender
TOMRR
Mass
1969 RR with manual brakes How does the push rod that (hooks to the brake pedal) pushes the plunger into the Master cylinder come off the plunger ?? I took a Alan bolt off the end of the plunger but no dice, does it just pull out ??
moparmonk
Hermon, Maine
There is a rubber expansion collar in a recessed area of the tip of the push rod. ( A new one usually comes with a reman master cyl). Once it is pushed in the master cyl, it does not like to come out. (otherwise it would be laying on the floor when you need that 100 to 0 stop). I have broke the master cyl before trying. If the master cyl is bad, no worries as it is probably a core anyway. Try putting the rod in a vice and hold it, and then try to pry the master cyl off it lengthwise. Maybe a heat gun in that area may soften up the rubber too? Pry with a big screwdriver or punch that pushes on the center of the master cyl. Be careful not to bend the little triangle piece that holds it in the housing. Let us know!
TOMRR
Mass
Thanks for the reply !! I have the rod and plunger out of the Master just can't get the plunger off the rod ?? Should I put rod in a vice and try to pound the plunger part off ??
moparmonk
Hermon, Maine
pinch the rod in the vice tightly with the aluminum plunger off the end of the vice. Wedge your screwdriver (or two, one on each side of the plunger) against the vice and try to pry off the plunger. It will go dry!
TOMRR
Mass
Thank You !!!!! Got it
Thanks Again Tom C.
I put the piston in my vice and crush it... It's junk and a new one will come with the rebuild kit or better yet, the new master cylinder. It will break and the push rod will come out easy.
