New Gas Tank
Steve
Chesterfield,England
Fitted this a few months back and now no longer have to change the fuel filter every 5 mins due to crud being sucked up.The sender had seen better days as well and only registered 3/4 full when tank was at the brim so new one of them fitted also and I now get a full sweep :thumbsup: Here's 2 pics.
I need to do the same thing to the 300. A clogged fuel filter left us on the side of the road in Iowa on the Power Tour in June.
Great job Steve! :thumbsup: Just one question, how did you manage to get a new sending unit that actually works properly? It seems like everyone else has problems with them!!!
lookin good Steve! my sender works fine.
Steve
Thanks for the positive comments guys.
Roadcuda said:
Great job Steve! :thumbsup: Just one question, how did you manage to get a new sending unit that actually works properly? It seems like everyone else has problems with them!!![/quote
I guess I was lucky.I also remembered reading on here to bend the float arm to ensure you got a full sweep.It's been well worth joining this site for the hints and tips as well as the banter :thumbsup:
6R9Runner
Atlanta, GA
This topic inspired me to remove my sender, which had a range between E and 1/4 even when topped up. The geometry of the repos is slightly different than the original, apparently just enough to mess up the gauge. In my case, the float arm needed to be bent down to make the sender read less than 50 ohms. Its probably an iterative process for any car with a new gas tank or a ride pitch that differs from stock. If you put it in and it works that is lucky! :thumbsup: At least I know now that for my car, a reading greater than 31 ohms allows me to remove the sender without getting a gas bath.
UPDATE: its now reading 1/2 with a full tank. One more adjustment should get it. :drive:
