Reverse lights
dmartin
Hey fellas my back up lights do not work I am not getting power to the lights so I went under the car and reversed the plug still nothing so what next, now my neutral safety switch works
check the fuse?
wires hooked up under the hood?
Might be something as simple as a ground wire. Check all grounding. My buddy put a motor in a golf cart called me and said the new motor starter was bad. He took it apart I had to put it back together. Said had to use pull rope and it would not shut of with the kill switch. We put a ground on it and every thing worked imagine that. Hope it is something simple Russ. :elmer:
and...there are light bulbs in the lights? seriously...there was another guy on here a few years back couldn't get his back ups working....then he figured out he didn't have bulbs.
