Steering wheel
Say guy's got a different steering wheel for my car. It has the trident pad and half horn ring. When removing my old one which had the center horn pad type. I have a gap between the upper column trim that the turn signal switch and all is in. Should their be one with the new steering wheel. The old steering wheel has a grove in it and that it is long enough to sit over that cover better. Am I missing something to help trim it off better. Any ideas will be appreciated. Russ.
When it is back together and I will put the steering wheel on and take some pic's. Then may be we can figure it out better. Just think must have a different column than what this steering wheel cam off of. Like a column shift might be what the difference is. Just don't know. Mine is not a column shift. Just to say.
